Help! My rear defog does not work! It has never worked for me ( i.e. the light won't come on, the window will not defog lol ) and I'm just now getting to it, had bigger problems to deal with earlier. What could be the problem? Is there a fuse I should look for? Maybe one of the lines is broken? I have no idea! Thanks guys!
Rear defog does not work!
lol, I couldn't have typed that better myself. I have the same problem, just never have fixed it. I'd also like to know about this.1999 Silverado- Bagged, colormatched and rollin on stock chrome 16\'s<br />Make love not war, hell do both, get married
i think that i read just a littl while ago about a guy with a 97 and he said that in the fuse panel there is a 30 amp breaker that has the defroster on it. he said that the breaker keep flipping, so he put a 30 amp fuse in and it worked fine. i have the same problem as you guys, i just haven't had a chance to check on this, so best of luck.2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
yeah i have the same problem..
only mine does work... for about 30 seconds and goes off, then i cant try it again for like 15 mins. again, im not real concerned about it, but if it is something as simple as a fuse i might get it fixed... BY NEXT WINTER!!!later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
<blockquote>quote:</font><hr>Originally posted by aalugo2000:
only mine does work... for about 30 seconds and goes off, then i cant try it again for like 15 mins. again, im not real concerned about it, but if it is something as simple as a fuse i might get it fixed... BY NEXT WINTER!!!<hr></blockquote>
mine did that too thankfully it was still under warranty. I can tell you what I know but I'm not sure. They told me it was a relay of some sort. Mine worked the same way yours (aalugo2000) did. I guess the relay was telling the comp funky times, but maybe that helps. Best I got [img]smile.gif[/img]
Just had mine fixed under warranty. Tried replacing all fuses/breakers first. No good. Turns out the HVAC head unit was funky. The switch for the rear defrost wasn't getting power. Had to get the whole thing replaced. So try your cheapest options first (fuses etc) then check your lines (no breaks), then check the head unit.
