i went to the dealership and they said nothing was wrong, typical. I went back a few weeks later to take a tech for a drive. he hooded up a computer in the obdII port. I had no ses light but it was reading a cylinder 4 misfire. Its twice as bad when the a/c is on.Since then i had the wires, fuel filter, plugs, and injector replaced. They also moved the coil packs around. I went back to the dealership and they said i was running up a bill. I have 3 months left on warranty and until i settle this problem with the dealership, does anybody have any suggestions of what might be wrong. This topic has been discussed before but there had been no solid answers. thank you.
misfire under load (please Help)
99 firebird A4<br />W68 package, Y87 package,SLP ram air H.O.hood,Whisper lid,kn filter,Borla 3in. adj. cat back smallest plate, 180*powerstat, removed maf screen, 3 in. cat,ngk plugs, nitto 450 245/50 tiresTags: None
I had the exact same problem in my 3.4, the coil packs tested ok, but that ended up being the problem.
Mine would only do it when the car was warm.
I would suggest replacing the coil packs a - it may be only one, but do all 3 because it is under warnenty.
I only replaced the one closest to the engine and that was the one that caused the problem.
good luck
