OBDII code P0304 - FirebirdV6.com/CamaroV6.com Message Board
OBDII code P0304
  • OBDII code P0304
    My car just started stuttering really badly last night when I get on the throttle.It's never done before. It's kinda strange how it all of a sudden started happening. The OBD says that cylinder 4 is misfiring. Any suggestions? It's probably the plug, wire or coil right? My car has 47k on it. The coils are only 20 bucks each to replace. Is this a dificult item to replace.
    Bingo, you have a misfire. It's either the sparkplug, or wire, or coil, but likely, very very likely, the plug or wire. Simple replacement, and cheap.
    -Rob
      Thanks! Any idea how much a good set of wires would cost? Recommend a brand? Do better wires provide a noticeable increase in performance on the 3.8? Not to ask a dumb question, just wondering if you might squeek out another horse or two with good wires?
        I'm sure you squeek out a few extra horsepower going back to 6 cylinders from 5.
        AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
