Automatic Tranny can cause altenator problems?? - FirebirdV6.com/CamaroV6.com Message Board
  • Automatic Tranny can cause altenator problems??
    If you guys have read my previous posts then you would know i have been through 4 altenators in 2 weeks. There is obiously a short or some kind problem with my eletrical system
    from the outside everything looks ok and i cant find out whats up with my car!!!
    heres what i have been told the possible problems are
    1 theres somthing inside my auto tranny (cant remember what its called) thats shot and causing a short of somekind there is a wierd feeling of my tranny right now when it shifts so that may be it... i dont know
    2nd voltage regulator
    can anyone explain how that thing works. where it is, how it can go bad, how to test it??
    i cant drive the damn car cuz the altenator goes out 30 mins after driving it and causes me to use my lifetime warranty to go get a new one!
    anyone?
      <blockquote>quote:</font><hr>Originally posted by Big Tymer:
      <hr></blockquote>
      is the alternator from autozone?
      I've heard many bad things about their rebuilt alternators.
      millionformarriage.org
      Why stop people from getting married?
        <hr></blockquote>
        It keeps the charge voltage from going over it's set limit. ~14.4V
        It is located inside the alternator.
        It is tested doing a standard alternator load test at AutoZone.
        Disconnect ANY AND ALL aftermarket electronic devices and try again.
        [ August 26, 2003: Message edited by: Jason McCallister ]</p>
        Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
          <blockquote>quote:</font><hr>Originally posted by Jason McCallister:
          <hr></blockquote>
          ok then its not that cuz i have went through 4 with nothign hooked up on the last 2......
          they were testing bad also
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
