Overheating [Non-Camaro] - FirebirdV6.com/CamaroV6.com Message Board
  • Overheating [Non-Camaro]
    I have a Subaru that I can drive around in town and it's fine. I take it on the highway and it's fine. I exit off the highway and within' 5 minutes the temperature climbs rapidly. The coolant is forced out of the radiator into the expansion tank. The fans are running and the heater is blowing hot air. Still temp gauge is maxed out. Shut it off and let it cool...
    I have changed the coolant, t-stat & gasket, hoses and radiator cap. The water pump was changed about 6 months ago, so I am thinking that's OK. Still same scenario...
    Possible clogged radiator? I don't think it's the heater core because it's blowing hot air.
    Any suggestions?
    Thanks
    --Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
    i hope you didn't trade in the camaro for the subaru...that could be your problem right there lol [img]smile.gif[/img] camaro is getting back at you haha...
    but it could be a clogged radiator...ever have a radiator service done on it?
    1997 Camaro RS A4 <br />3.08 Rear<br /><a href=\"http://www.cardomain.com/memberpage/470169\" target=\"_blank\">http://www.cardomain.com/memberpage/470169</a><p>Mods:<br />SLP Cold Air Intake<br />Flowmaster 80 Series Muffler <br />MSD Ignition Coils<p>Soon to be installed:<br />3.42 Gears<br />MSD Plug Wires
      No, traded the Camaro in on the Xtreme [img]smile.gif[/img]
      I was thinking radiator also.
      Only service is the stuff I have done, flush and refill.
      Thanks
        Before you get a new radiator, you may need to make sure that you don't have any air trapped in the system. Expanding air will force coolant through the overflow.
          <blockquote>quote:</font><hr>Originally posted by Jerriko:
          Before you get a new radiator, you may need to make sure that you don't have any air trapped in the system. Expanding air will force coolant through the overflow.<hr></blockquote>
          I bet you are getting hot spots in the car. my guess is that you have air trapped inside the coolant system somewhere that is causing certain parts to heat up a ton. [img]graemlins/thumbsup.gif[/img] The other thing to do is get a pressure test.
          Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
            I did the the factory bleed air procedure. Warm up with radiator cap off, bleed valve open until coolant flows from bleed valve.
            I thought air too, but then I would get heat from the heater.
            New radiator is on the way. $134 from Radiatorbarn.com brand new, lifetime warranty.
            Every where else they want $250-300!
            Thanks
              may sound dumb but i bet it has an electric fan are you sure it is coming on at the proper temperature
              *ASE CERTIFIED* <p>Don\'t Laugh Your Daughter Thinks it\'s Cool...
                <hr></blockquote>
                I am not sure what you mean by that. You would get heat from the heater either way, air or not.
                  <blockquote>quote:</font><hr>Originally posted by badandy247:
                  may sound dumb but i bet it has an electric fan are you sure it is coming on at the proper temperature<hr></blockquote>
                  2 actually. Fans are on and seem fine.
                    <hr></blockquote>
                    My understanding of the system is that if there was blockage (in the heater core) or air in the system the heater core would not be operating "100%" (ie. luke warm).
                    • 187shark
                      by 187shark
