Headlight Mod - FirebirdV6.com/CamaroV6.com Message Board
Headlight Mod
  • Headlight Mod
    Hey Ken, long time listener, first time caller here. Actually, after 10 days of waiting anxiously I finally get to post!
    I performed the headlight mod last weekend in conjunction with the changing of burnt out fog lamps. And I learned:
    1) Do not use Chilton's 1993-1998 Camaro/Firebird manual if you have a 98. They treat it like a 97 with the sports package. Why does this matter? In the 98, you have two screws holding a poke through opening in the front air dam. Remove them and you can reack up to get the fog lamp.
    2) After the modification, the fog/outside and inside headlamps come on as well as the fog lamp indicator in the car when the highs are turned on. [img]graemlins/omg.gif[/img] (all I did was ground the fog lamps) I can't remember, but in the 98 didn't the inside lights turn on, and the fog and outside lights turn off when you turned on the brights?
    That's about it.
    Rob
    <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
