I took my A/C out and now i am putting it back in i have a recharge kit and measering kit and two cans of r134a but is there anything else i need to do or can i just turn on car turn on a/c and fill
How to redo A/C
How to redo A/C
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
<blockquote>quote:</font><hr>Originally posted by slacker69:
I took my A/C out and now i am putting it back in i have a recharge kit and measering kit and two cans of r134a but is there anything else i need to do or can i just turn on car turn on a/c and fill<hr></blockquote>
I just recharged the cavvys and the porsche and you just connect it, turn the engine on and A/C full blast full cold and let her go :DBlack 96 Z/28, A4, T-tops, tint, 2.73 LSD, Kenwood.<br /><br />Previous Camaro: Bright white 86 Camaro, MPI 2.8 A4 3.42, tint, Z-28 wheels, a few goodies.
Cool i just did it and i got cold air again hell yeah good thing goes it has been like 100 degrees outside lately<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Too late now, and not anything critical. But since they are so cheap, I usually reccomend installing a new oriffice tube. (filter for the A/C system)
And I also like to use at least one small can of refridgerant WITH oil in it. Just to make sure everything stays lubricated.
Good deal you got it back though.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
They are normally sold along side cans of refridgerant, and its probably a common purchase but oil in not always contained in each can. The can with only refridgerant will cost less than the can with refridgerant and oil in it.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
I'm moving this to general tech.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
you were supposed to put a vacuum on the system to get all the air out before you put and refridgerant in, and then you can start filling it without it on so that you don't have a compressor running with nothing in it and it overheats and tiny fragments of metal get circulated through the system eventually ruining the compressor and then you'll have to buy a new or reman one and flush all the lines and buy a new expansion valve. But that's just a worst case scenario. What you have done will be fine, except it probably won't be cold next summer anymore with the air in the system.1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...3 weeks ago
