160 stat and IAT resistor? - FirebirdV6.com/CamaroV6.com Message Board
  • 160 stat and IAT resistor?
    I have a 96 and want to put in a 160 stat. do i need the IAT resistor? will it help for power at all let me know? I am in arizona so I want my car to run as cool as possible. i Know this has been covered but in my search I coldnt find if on a 1996 the resistor on the IAT would help? thanks.
    white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
    i heard the IAT will only give 1 extra HP. you should get yourself a fan switch also. helps out a good bit to keep your engine cool.
    99 firebird 3.8 v6 A4 orange with 2 pearl white stripes, throttle body spacer, k&n, 3.23\'s, ram air,airbox mod, flowmaster, no cat, rollin on 245/45/16 kumho ecsta\'s, tinted windows, sony xplod cd player, jensen 800 (old model) and 12\" audiobahn
      <blockquote>quote:</font><hr>Originally posted by white96six:
      I have a 96 and want to put in a 160 stat. do i need the IAT resistor? will it help for power at all let me know? I am in arizona so I want my car to run as cool as possible. i Know this has been covered but in my search I coldnt find if on a 1996 the resistor on the IAT would help? thanks.<hr></blockquote>
      Nope, 96's are fine without it. You only need the resistor for 01/02 model cars, due to a PCM code change. It is not used for more power, its used to eliminate the gauge failure/fans kicking on high/ses light issue with the late model V6s.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        thanks alot. :cool:
          2 days ago
        • Doodler
          97 Camaro base with expensive sounding noises
          by Doodler
          Still trying to find oil leak
