Hi, I recently put an 80 series FM with some wide tips on my 2000 3.8l. Everythings cool but I've noticed the A4 shifts differently since the install. It seems to be a little confused at slow speeds under 40 mph.To me it's shifting too early. It has a problem with third to fourth. Kicks into 4th a little to early.It annoys me cause it give a little push when it goes into 4th. I've had the FM on for over 1000 miles so I think the PCM is adjusted by now. I am changing my tranny fluid to see if that helps. It seems to shift a little rougher since the new exhaust install. Cars only got 37k on it. Is this normal? Thanks.
[ September 01, 2003: Message edited by: GBH ]</p>
<blockquote>quote:</font><hr>Originally posted by GBH: Hi, I recently put an 80 series FM with some wide tips on my 2000 3.8l. Everythings cool but I've noticed the A4 shifts differently since the install. It seems to be a little confused at slow speeds under 40 mph.To me it's shifting too early. It has a problem with third to fourth. Kicks into 4th a little to early.It annoys me cause it give a little push when it goes into 4th. I've had the FM on for over 1000 miles so I think the PCM is adjusted by now. I am changing my tranny fluid to see if that helps. It seems to shift a little rougher since the new exhaust install. Cars only got 37k on it. Is this normal? Thanks.<hr></blockquote>
well I have had my flowmaster 80 series on for about 8 months and 20,000 miles (I have 48,000 now) and I never noticed a difference in anything except noise.
btw this should probably be in the intake/exhaust section
