Parking Brake Adjustment - FirebirdV6.com/CamaroV6.com Message Board
  • Parking Brake Adjustment
    Does anyone know how to adjust the parking brake on a 01 firebird? everytime i pull the parking brake, the handle is almost vertical for the brakes to actually hold.
    mine is very moody so i would like to know as well. sometimes i pull it and it works fine, and other times i pull it and it'll go completely vertical and not do a damn thing
    <a href=\"http://www.cardomain.com/memberpage/764442\" target=\"_blank\">http://www.cardomain.com/memberpage/764442</a>
      tru adjusting your rear brakes..
      go in revers moderately fast and slam the brakes. repeat 3 or 4 times.
      96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
        how does goin in reverse and doin that help anything?
        1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
          well, since i dont know what car you have, if you have rear drum brakes, they self adjust when you brake in reverse.
          2000 3.8 A4 Pewter Camaro
            he has a 2001 firebird. going backward will not work with his ABS disk brakes.
            the 4 wheel disk brakes are self adjusting. owners manual says to 'brake hard' (while going forward) once or twice to periodicaly adjust the disk brakes.
            (this is the same for many 4 wheel disk brake cars)
            as far as adjusting the E brake....i know that under the car (below the back seat) is where the e brake cable has a conection to the cable assembly of the axle. it might be there. that connection might have a swivle adjustment. but that is what you are looking for...look under the car and follow the e brake cable...look for an adjusting point. hope this helps.
            i misplaced my haynes manual.
            01 Firebird A4 3.42
            Powerdyne @ 6 PSI
            and other mods
              ok thanks. i'll look for it the next time i get under my car. :)
