So who DOESN'T have rear main seal problems? - FirebirdV6.com/CamaroV6.com Message Board
  • So who DOESN'T have rear main seal problems?
    just wondeing...
    My engine leaks no oil whatsoever.
    173K on it. :D
      I might have asmall, slow drip that doesnt even hit the ground. Only since i went over the curb and dented the oil pan though, so probably not rear seal. Got about 45k on it.
      97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
        never once in the V6 (RIP 69xxx miles)
        Nor in either LS1 vehicle I've owned.
        In the DSM, though...that thing was a rolling oil leak.
        2011 Camaro LS 6M, in black.
          I do not have a rear main seal oil leak on my '96.
          However, the GM part number for the oil drain plug *gasket* is #14090908. Comes in a package of 5.
          It is a steel washer with a neoprene rubber seal molded in, highly recommended.
          The cheap rubber seals, available at Autozone for example, get chewed up on the threads when reinstalling the 15MM drain plug and causing a slow oil leak centered where a rear main seal may leak therefore throwing you off for what may not be a bigger problem.
          Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
            I have a slow leak that has always been there, never really worried about it. Never need to add oil or anything.
            http://www.bowtiev6.com/
              what have you been told about "x2" posts??
              [ October 19, 2005, 07:19 AM: Message edited by: navyblue2000 ]
              2000 3.8 A4 Pewter Camaro
                i found tranny fluid on my head after 3rd and 5th gear went [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                www.turbov6camaro.com
                1997 3800 Series II Camaro
                  haha how in the **** did you do that?
                    no idea
                      I think i have a small leak....But i havent found it yet. I know my powersteering leaked all over the place.
                      95 black 3.8 camaro, Intake, Pacesetters, Flowmaster 80 series, accel plugs and wires, B&M shift kit (eh could be better), hopefully a highflow cat soon. and a bunch of appearance mods.
                        PS leaks a bit, although it's not as bad since I changed to synthetic PS fluid.
                        Engine leaks a bit on to the Y pipe,(small drips on floor).
                        I'm going to try the drain pan plug. Seems to be getting worse with each oil change.
                        Thanks for the tips.
                        Mike
                        Mike,<br /><br />Last RS<br />Vancouver Island, BC<br />1997 Camaro RS, Bright Green Metalic, SS Take Off Exhaust, Zexel LSD
                          no leaks for me. not a single 1 at 90,000+ miles.
                          Visit My F-Body Page
                            BLLDOG...that's your final warning on this "x2" crap.
                              mine leaks, 89,xxx miles. I honestly think it's more of a 5-speed thing. We don't have that heavy torque converter to help soften the shifts. And it's been leaking since about 45k miles. In a 3-4k mile oil change I think I loose about a half a quart or so between normal consumption and the leak.
                              -Brad
                              2000 V-Star Custom 1100
                              :rock:
