94 3.4L oil change - FirebirdV6.com/CamaroV6.com Message Board
94 3.4L oil change
  • 94 3.4L oil change
    Hey all,
    I know this has probably been asked a million times but I searched and couldnt find it. How many quarts of oil does the 3.4L v6 take? I lost my owners manual, drained the oil and now Im kinda up the crik until I find out.
    Thanks
    I remember something like 4.3 quarts. I know that the .3 is hard to figure out, so just put in 4 quarts and then sneak up on the last amount by waiting a few minutes and then checking the dip stick and adding a little more until it's full. Just wait a few minutes btwn each time that you add some and when you check it.
    Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
      i put in 4.5 quarts then i check the dip stick. i turn the car on let it run for a minute. turn it off and check the stick again until its full
        in my dads car, i put around 4.5 quarts in, then START the car to get oil in the oil filter, and see how the level is... and add mroe as needed
          mine takes 8 quarts lol
          Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
            dman white! do you have some sort of dry sump system? modified oil pan? or jsut some sort of remote tank? i cant imagine you needing 3.5 extra quarts for just the turbo...
            speaking of, hows that comin along? i havent heard anything new on your project in quite a while... im interested in that cause i plan on doing something similar to what you were doing...
              its done i'm tunning it as we speak. and i plan on modifying the turbo kit and make forward headers and lt1 intakes for the 3.4 so i've been very busy
              i have a deep pan that holds an extra 1.5 qrt an oil cooler which hold about a 1 qrt and then the turbo lines.
                the 3.4 stock oil filter (for AC Delco) is part number PF47. If you buy PF52 (the kind used on the 4.3 GM V6), it will increase your oil capacity to a full 5 quarts.
                I have been using the PF52 size for a long time with no problems.
                --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
                  So we can use a 90° Vortec 4.3 oil filter on our cars? Same engine used in the 90's Blazer/Jimmy right?
                    AW!! Where did you get the pan? I havn't been able to find one... I want one, erm I take that back I NEED ONE!
                    1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
                      Originally posted by Nikos95:
                      </font><blockquote>quote:</font><hr />Originally posted by White95:
                      AW!! Where did you get the pan? I havn't been able to find one... I want one, erm I take that back I NEED ONE! </font>[/QUOTE]I had it custom made. All you need to do is take to a machine shop and tell them to add about 2" in the middle of the pan all the way around. You'll have to modify your pick up as well
                        </font><blockquote>quote:</font><hr />Originally posted by Nikos95:
                        AW!! Where did you get the pan? I havn't been able to find one... I want one, erm I take that back I NEED ONE! </font>[/QUOTE]I had it custom made. All you need to do is take to a machine shop and tell them to add about 2" in the middle of the pan all the way around. You'll have to modify your pick up as well </font>[/QUOTE]What did you have to do to your pick up?
                        I need to do this cause this 5 quarts of oil thing isn't working, I run high rpm too long sometimes, and I'm thinking about a gravity fed saver tank on top of a larger pan, and maybe even a cooler.
                          you have to bend/extend the pipe. i'm not 100% sure though because i had the machine shop take care of it when they built the motor
                            that is correct
                              FYI. 4.3 quarts of oil is for the 3.4 Camaro.(don't forget to wet the gasket)
