Ok, 1997 camaro V6. ive called every place in town and they all tell me NO ONE makes a tuner/programmer to remove my speed limiter. What are you guys using, what is the maker and part number. Hyper tech makes one for camaro v6 but only for 2000-2002, will that work on my 1997? thanks
1997 speed limiter
1997 speed limiter
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
I think hp is too complex for what i want to do. all i want to do is remove speed limiter and maybe the rev limiter also.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Originally posted by BobbyZ72:
limiter and maybe the rev limiter also.www.turbov6camaro.com
1997 3800 Series II Camaro
what?? i wont blow my motor, i just dont like a computer limiting my car. And if i do blow it ill buy another.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
you can remove the speed limiter (mine is set at 250) be NOT the revlimiterwww.turbov6camaro.com
jet scu2000 removes the speed limiter and fixes for gear changes
or hp tuners for the full tuning aspect
im not racing or anything like that. i just dont like the computer limiting my speed.. i mean my grandmas honda civic will go faster then my car...MY GRANDMA WILL PASS ME!!! What about hypertech, i think thats what i really want. but which one will work on a 97 v6?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
is is really bugging my for the past few months...its scary but im really liking the way those new 2006 honda civics look, with 5 speed autos.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
im not racing or anything like that. i just dont like the computer limiting my speed.. i mean my grandmas honda civic will go faster then my car...MY GRANDMA WILL PASS ME!!! What about hypertech, i think thats what i really want. but which one will work on a 97 v6?www.turbov6camaro.com
I had a 1999 before i bought this 97. the 99 i guess the last owner had somehow removed the limiter. That car would easly hit 125, and still be gaining speed. I had to start to slow down pretty quick after passing 125mph because the rearend started feeling loose, as in loosing good traction and wanted to step out of line. So to anwser your queston...hell yes it will go much faster then 118! My next question for you guys is why the hell would chevrolet make the the gauge go to 125 when the car will only do 118. Guess the dumb Engineers could not calibrate it that way. In my oppion its just to make it look fast. And that if it goes faster then that all my leaking seals will totally blow out [img]smile.gif[/img] yall know what im talking about...all the leaks...i had all mine fixed. now i think the oil pan gasket it leaking again. I have a drip fixing to fall right now after only 3 months and 2000 miles. The next car i buy, on my test drive im going to make sure the car will do ATLEAST what the speedometer says.
[ October 23, 2005, 08:50 PM: Message edited by: BobbyZ72 ]<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
