1997 speed limiter - FirebirdV6.com/CamaroV6.com Message Board
1997 speed limiter
  • #16
    Well I think that with only basic mods and 3.42 gearing, an auto/manual car should be able to hit close to 140 or so.
    I really don't understand what you guys keep asking "How much faster do you think you can go"
    A Mazda Miata with it's huge 1.8 4 cylinder will hit 142 topped out.
    So with that in mind........I should be able to hit at least 150 or so (and at Brainerd Raceway for all the "why on the street guys"). Who knows how fast you could get with a nitrous shot or a power adder. Probably 160 plus.
    • #17
      Your tires are only rated for 118MPH, T rated, so after that there's a good chance they fail, and you'll be seriously, if not fatally, hurt when your vehicle hurtles out of control.
      ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      • #18
        Originally posted by BobbyZ72:
        I had a 1999 before i bought this 97. the 99 i guess the last owner had somehow removed the limiter. That car would easly hit 125, and still be gaining speed. I had to start to slow down pretty quick after passing 125mph because the rearend started feeling loose, as in loosing good traction and wanted to step out of line. So to anwser your queston...hell yes it will go much faster then 118! My next question for you guys is why the hell would chevrolet make the the gauge go to 125 when the car will only do 118. Guess the dumb Engineers could not calibrate it that way. In my oppion its just to make it look fast. And that if it goes faster then that all my leaking seals will totally blow out [img]smile.gif[/img] yall know what im talking about...all the leaks...i had all mine fixed. now i think the oil pan gasket it leaking again. I have a drip fixing to fall right now after only 3 months and 2000 miles. The next car i buy, on my test drive im going to make sure the car will do ATLEAST what the speedometer says.
        that masda also has alot less wieght then our car.... a full stock car i dont see it getting much over 130-135
        www.turbov6camaro.com
        1997 3800 Series II Camaro
        • #19
          Whats a MASDA? My tires are all brand new and not the cheap T rated tires, that yalls cars have. Looks like if im going to keep the car im going to have to take that long cruse down to texas speed. Looks like about 5 hour drive from here. Im sorry but i just cant have a computer limiting my car at a silly 118mph. I dont race or hardly speed, just if i get a wild hair to show off i want my car to be able to do it.
          • #20
            sorry man its a waste, after 100.... stock our car fall on there face the only resaon to take the limiter off is for the track or dyno,
            lol my tires were $275 each. not every has stock tires..... you come on posting like you know more then all of us and have a better car or something
            your doing this for all the wrong reasons
            [ October 27, 2005, 08:51 PM: Message edited by: viper04af ]
            • #21
              LOL...i didnt mean it like that, thats just the way it came out. My tires were 265 each also.
              • #22
                Um.. Mine are 175 each you guys getting ripped off on tires or something?
                95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
                • #23
                  http://www.tirerack.com/tires/tires....e1=yes&place=0 &lt;&lt;&lt; i have the Z rated and 18months ago when i got them they was back ordered for 2-4 weeks
                  • #24
                    sorry mine were 165 each..not the 265... dont know why i was thinking that.
                    • #25
                      can you give us the mail of texas speed, becouse i am interesting to remove the speed limiter. thanks.
                      Camaro RS 97 3.8 MSD Ignition Kit.<br />Cold Air Induction.<br />30 Aniversary
                      • #26
                        jesus you guys pay to much on tires...
                        I spen $107 on my tires...
                        You don't plan to really go past 118 ever yet you want to spend $275 to take off the limiter?
                        put a toggle switch in line with the VSS. Your speedo will go dead.
                        jesus christ... $265 a tire vette run flats autocrossing slicks and drag radials are all cheaper.
                        • #27
                          PS I would look into the Jet SCU... probably the cheapest way to get rid of the speed limiter.
