P0449 code won't go away!! - FirebirdV6.com/CamaroV6.com Message Board
  • P0449 code won't go away!!
    Hey everyone. I ran a diagnosis scan because my SES light was on, and I get the P0449 (Evap. thing) code. I got this yesterday and all I had to do was tighten the gas cap even though it was already tightened. This time, it won't go away! I need to fix this ASAP as the guy who's buying the car will be here saturday. Thanks!
    2001 3.8 Camaro<br />-FTRA, Whisper Lid, K&N Filter<br /><a href=\"http://members.cardomain.com/jaberocs\" target=\"_blank\">members.cardomain.com/jaberocs</a>
    could be more than just the gas cap needing to be tightened.
    thats just a first thought
    http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=015479
    did you have the computer reset?
    Visit My F-Body Page
      P0449 sounds like a possible problem with the EVAP vent valve, or some wiring between the PCM and the valve.
      Matt
      1998 Mystic Teal Camaro M5
        i tried reseting my computer by disconnecting the neg. batt. terminal (right way to do it?), but my power stayed on. It was strange, I never had that happen before. I had the door open when I disconnected it, and the lights stayed on.
        Originally posted by jimbovia:
        I have heard that the EVAP cannister beads will float or bounce up and block the outbound gas vapor tube causing the EVAP Purge control Solenoid to pop a code.
        I hope that's the reason why it's acting all weird now.
          disconnecting the battery will not erase a code. ;)
          2000 3.8 A4 Pewter Camaro
            lol. i know, i was trying to reset the cpu. the ses light went away for like half a day even though i didn't do anything, but then it just came back.
              The EGR valve (driver side exhaust) is probably sticking.
              Raven
                P0449 is EVAP, not EGR. They're not related in any way. [img]smile.gif[/img]
                Matt
                  Turn the ignition to on and pull the pcm fuse under the hood on the drivers side. Wait for aprox 3 mins and turn the ignition off and reinsert fuse. If the code comes back it might be a defective cap.
                  [ November 06, 2005, 01:57 AM: Message edited by: Tony2.8 ]
                  1988 Camaro 2.8L 130hp/160tq<br />2001 Z28/RS Convertable 410rwhp/400rwtq
