Intermittent tapping unrelated to RPM - FirebirdV6.com/CamaroV6.com Message Board
  • Intermittent tapping unrelated to RPM
    This one is really bugging me. I'm getting this tapping that is unrelated to engine RPM or speed. It'll happen while cruising, clutch in or out, or while idling. It's a little loud...sounds kind of like a bad lifter, but it's at a constant rate of about 5 times per sec.
    Hard to pinpoint where it's coming from because it'll stop after 10 seconds of idling, then I have to drive it to make it start again. Either from the driver's side of the engine or under the driver's dash.
    The fact that it's at a constant rate tells me it's not something mechanical in the engine, but I just can't figure out where it's coming from. Was thinking maybe it was some kind of vibration, but it's the same every time.
    Any ideas?
    Matt
    1998 Mystic Teal Camaro M5
    Sounds like it might be a loose exhaust hanger.
    My only camaro rattled like that. It took me months until I saw the exhaust was really close to the crossbrace under the car. I raise the exhaust piping and retightened the bolt. Then again, I had an aftermarket cat that didn't have both bolts to mount to the hanger.
      pull your belt maybe?
      both my 3.4 and 3.8L both had a tick from a pulley for some reason I just WD40 behind them and it stopped.
        Eric, where ya been?
        Anywho, in my weekly forum trolling, they're talking about you again. http://www.my350z.com/forum/showthre...1&page=1&pp=20 Its at a 350z page this time though.
        Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
          /\ hahaha [img]graemlins/rofl.gif[/img] that was good reading.
          Eric PWND them
          Follow me!
          Or this
            haha, that guy with the '95 gts mustang got 3wned badly.
              Thinking it may have something to do with the injectors. When I get off the gas and coast down, the noise stops. As soon as I touch the gas, it starts back up. Seems to coincide with what the wideband shows regarding DFCO.
              Just what the noise could be is still a mystery. If it were an injector making the noise, I'd expect it to change with RPM, yet it doesn't.
              Matt
                would you say the noise is excessive when the engine is under load? could possibly be a blown header gasket, which can sound very mechanical but is also directly related to engine RPM.
                could also just be the everpresent injector pulse.
                  Definitely not an exhaust leak of any kind.
                  I would lean toward just an injector tick, except that even that would change with RPM.
                  Matt
