coming up on 75,000 miles - FirebirdV6.com/CamaroV6.com Message Board
  • coming up on 75,000 miles
    What I should I expect to go wrong with my car in the near future? Its a 2000 A4.
    <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
    What have you replaced so far? and at what mileage?
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      Wires and plugs...if they havent went already.
      O2 sensor
      PCV Valve....
        I did my wires, plugs, and pcv valve last year. I've got Taylor wires on there right now, about how long do those wires last for?
          Generally I saw some minor transmission problems occur depending on your driving habbits and transmission maintenace. Window and headlamp motors were very common replacements(especially if you do not remove snow and ice fromt them). Rear brakes should be coming up, check your rotors for pitting. Coil packs might start arching or develope corroided terminals. If you have not had your injectors cleaned then you might see some of them get stuck here and there.These are all problems that I saw at the dealership not on the same cars.
          Previous F-bodies<br />1.1980Z A3<br />2.1991Z A4 5.0<br />3.1994 coupe M5<br />4.1993 TA A4<br />5.1998 coupe A4<br />Currently restoring a 1980Z<br />and looking to pick up a 1998-2002 M5
