Car is Shutting Off While Driving!! - FirebirdV6.com/CamaroV6.com Message Board
  • Car is Shutting Off While Driving!!
    Hey guys. Ive come across a problem with my 3rd gen 1990 firebird 3.1. Every once and a while my car stalled out when i put it in drive or reverse and ive had to restart it. This is at normal driving temperature. But recently it shut off one night while driving. It came to a rolling stop, and i got to restart it. But now its not even starting. At first i though electrical, but now i think fuel. I just wanted to know if anyone else has experinced this problem. Thank You
    Replace your fuel filter if you haven't done so in awhile.
      Try a fuel pressure gauge
      1988 Camaro 2.8L 130hp/160tq<br />2001 Z28/RS Convertable 410rwhp/400rwtq
        Dude. i had the same problem with my 89er. Check for spark. your ignition coil could be going out. mine did the same exact thing. Check your distributor compents, and plugs. definalty check ur sparks .
          I tested the with gauges; fuel gauge= good pressure, no backed up lines. Good compression, good spark. Im seriously thinking maybe the EGR system or extremely faulty exhaust?
            If fuel and spark are good, it's probably MAF, causes a lean condition and stalling. Will usually throw a code 44. Have you gotten any SES lights? If so, done the paper clip trick to read the code?
              Seems you have an intermittent battery connection which will also cause this shut-off condition. A vehicle in motion with a loose connection will play games with your head.
              Recheck, tighten terminals & clean any signs of corrosion.
              Happened to me while I was driving my '91. I hope that's your problem.
              Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
                also when checking battery terminals check ur ground connection. it mihgt have wiggled its way loose
                '99 Camaro Y87 M5 T-tops
                Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
                Car Domain
