car started and died after 3 secs - FirebirdV6.com/CamaroV6.com Message Board
  • car started and died after 3 secs
    ok i got in my car to start it and it dies after a couple secs. well i treied a few more times and same thing well then i tried my remote start and same thing well after about the 10 time itr started and ran. what could this be i dont want it to happen in the future
    Unfortunately it could be a million things, most common might be the fuel pressure is weak. Some GM vehicles if the fuel pressure is below spec it would not start at all.
    Previous F-bodies<br />1.1980Z A3<br />2.1991Z A4 5.0<br />3.1994 coupe M5<br />4.1993 TA A4<br />5.1998 coupe A4<br />Currently restoring a 1980Z<br />and looking to pick up a 1998-2002 M5
      yea well after i first got the car about a year ago i had a bad body control module i went and got one off of a 98 camaro at a junk yard and well i plugged it up car started and died after 3 secs...so i had to buy a brand new one and i dont think that is the problem i was told my fuel filter could be bad but it aint happened to me again yet
        Check the IAC.
        1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
          could be fuel pressure regulator.. not that expensive
          1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
            whats the iac
              Idle Air Controller.
              It's on the throttle body. I has two torx bolts holding it in. A little plastic part. If you pull it out you will see a spring-like plunger appendage.
                2 days ago
              • Doodler
                97 Camaro base with expensive sounding noises
                by Doodler
                Still trying to find oil leak
