What are the stock tire sizes from the factory. When I bought my 96 Camaro the guy had P235/55R16 Cooper Cobra Radial GT's on them. I know that the Coopers are not the stock tires(or stock brand) but is that the still the stock size?
Stock Tires
i have the 235's on my 2000. dont know if the tires r stock though. bought the car used
Originally posted by SilverFire:
i was just curious what number determines the height (low profile-ness) of the tire. i was looking for something more low profile for my car. right now i believe that i have 245/60/16.
[ May 12, 2004, 01:04 AM: Message edited by: andrew.brandon ]95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
245 = Width of tire
60 = 60% of width is sidewall height
16 = 16 inch rim
Mine - 275/35R18
275 = Width of tire
35 = 35% of width is sidewall height
18 = 18 inch rim
If you go any lower profile on your stock rims your speedometer will be off.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
What sidewall ratio would allow me to use 245's on 16" rims and still maintain the stock outer diameter of the tire to keep the speedo accurate?96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Originally posted by MegaHertz:
What sidewall ratio would allow me to use 245's on 16" rims and still maintain the stock outer diameter of the tire to keep the speedo accurate?I solemnly swear I am up to no good.
wat size tire wall would you need to get to keep the speedo the same when increasing to 17" or 18" wheels...if it is possible?1997 Camaro<br />17x9 Chrome SS wheels, SLP CAI, Magnaflow Catback,<br />High Flow Cat, Blacked out Lights, 20% tint, AUDIO: 1600W Kenwood eXcelon Amp, 12\" Kicker L7, 1 Farad Cap (Recently STOLEN),<br />H&R Springs and KYB AGX\'s,<br />Billet Grille
