fuel injectors - FirebirdV6.com/CamaroV6.com Message Board
fuel injectors
  • fuel injectors
    I am ordering fuel injectors from Full Throttle Performance. They list 17lb,19lb,22lb and 24lb.
    Which one do I need? Is it better to order a 24 as opposed to a 17?
    It a 95 3.4...
      Why do you need upgraded fuel injectors? A stock motor is not going to make any more power (will actually make less power unless it's re-tuned) with bigger injectors.
      Now if you've got a blower or something, that's different.
      Matt
      1998 Mystic Teal Camaro M5
        he might just be needing replacements. that Matt, is something you should be able to answer. [img]smile.gif[/img]
        2000 3.8 A4 Pewter Camaro
          I just need replacements, I have a couple that are leaking when I shut the car off. When I start it up an hour later it runs like its flooded for about 10 minutes. Also, Finding replacements on this island is very expensive. I ones from FTP are much less than the $110 a piece over here. One more...Will I neeed to remove the lower intake to bring out the fuel rail? And, Is a TPS the same on a 97 3.8 as it is on my 3.4?
          Thanks
            you can get them for like 60 something apeice at gmpartsdirect.com or somethin like that...
            1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
              Unless you have plans to go crazy with mods, stick with the stock size of 17#.
              You won't have to remove the lower intake to swap the fuel injectors.
              TPS is not the same as a 3.8's.
              Matt
                2 days ago
              • Doodler
                97 Camaro base with expensive sounding noises
                by Doodler
                Still trying to find oil leak
