Part number for rear main seal on 98 3.8..preferably not the GM part - FirebirdV6.com/CamaroV6.com Message Board
  • Part number for rear main seal on 98 3.8..preferably not the GM part
    Maybe a Fel-Pro? Something that will last?
    Thanks for the part number.
    Sam
    WWW.OREILLYAUTO.COM shows 2 National seal numbers:
    320691 for $9.49
    99328 for $36.99
    You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
      FELPRO
      1 PIECE RUBBER BS40621-1 $15.89
      FELPRO
      1 PIECE TEFLON BS40649 $12.99
      Both @ Autozone.
        How hard is a replacement? More than pulling the oil pan? More than pulling the tranny and clutch? More than pulling the engine?
        -Rob
          More than pulling teeth when your stranded on a deserted island with a volleyball and a pair of ice skates ... if you don't have an auto lift.
            pull trasmission
            remove flex plate
            remove seal
            replace seal
            replace flex plate
            replace trasmission
            drink beer..
            pully a tranny isn't that tough just time consuming and dirty.. you can pull a transmission on jack stands you are just gonna need a helper and a floor jack and some common sense..
            -Brad
            2000 V-Star Custom 1100
            :rock:
              this bring up a good question.
              Since i'm getting my transmission replaced, would it be good for me to goto autozone and pick up 1 of those things that someone listed and have them replace it when they're ripping apart my car?
              also, which one is better?
              my rear main isn't leaking that bad, but it has a small leak that's a little noticeable when I change the oil.
                <blockquote>quote:</font><hr>Originally posted by gregmondro:
                <hr></blockquote>
                Hell yes!!!!!
                [img]graemlins/burnout.gif[/img] [img]graemlins/burnout.gif[/img]
                Max<br />\'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. 17.82 @76.101mph 2hp/5ft-lbs. :<a href=\"http://www.home.earthlink.net/~airspeedy2\" target=\"_blank\">The Home Page</a> <p>\'99.5 F-250 SuperDuty CrewCab, PowerStroke Diesel, 2wd, Torreador Red, TS Perfomance \"Insane\" Chip, BTS Tranny & Triple Disc Converter, Maddog Stage 2 Injectors, Holset H2E Turbo (36+ Psi), Detroit Locker, 33x12.5x17 Pro-Comp A/T on Eagle 118 17x8 Chrome wheels ......13.98@101mph. <p>Your resident California Licensed Smog Tech. :)
                  It would be a good time to change it and save some labor $$$. But, verify that it is really your rear main seal leaking and not the oil pan gasket seeping.
                  Does your car leave an oil spot in parking lots?
                    Hey I tried to use that Autozone part number for the rear main but it said it wasn't available. Anyone know the real number?
                      Not sure if its the same for you guys but I have had problems with seals that every brand seal leaked except the GM one. May be different then you, just because its aftermarket doesn't mean its better.
                        Well obviously my GM seal leaked, too. I don't know, stupid rear mains.
                          i think GM uses National seals anyways dont they?
                          <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                            bump
                            • Andy H
                              Transmission removal help!!
                              by Andy H
                            • 2.8 Bird
                              Abs inop
                              by 2.8 Bird
                            • fishin
                              by fishin
