last tank i got 13.3 MPG... no time at the track and wasnt driving any harder then i normally drive it. the tank before i got 15.1 MPG. what are some possiblities? its got 40,000 miles have not changed fuel filter ever have run a bottle of STP fuel system cleaner through a month ago...
MPG gone to sh*t
wow 15 isevenbad
i get like around 20 in my LS1 and I romp on it quite often2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
Check tire pressure. Low pressure snuck up on me a few times, killing my gas mileage. I make sure all mine are at 30psi and check it monthly now.
This is just one option...
:cool:1996 Arctic White Camaro RS with optional Y87 V6 Performance Package<br />2002 Sebring Silver Camaro SS with optional 345 HP Package
15 mpg???? down to 13???? wth?? i get like 32 on the high way an 23 in town!91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
Well you need to change the fuel filter for sure. I think it's supposed to be changed every 10K. If the tire pressure is good and the new fuel filter doesn't help then I'd try doing plugs and wires after that.<a href=\"http://www.cardomain.com/id/sean37\" target=\"_blank\">Black \'97 Camaro</a> w/ CAI, catback
as you can see from cale's response, the ls1 is quite efficient. so don't jump all over me for saying that i think the main culprit is in the 17" wheels you ride around in. the bigger the wheel, the more it takes to carry it, hence, worse mpg. the fuel filter is probably not likely because, if the fuel filter were bad, you would be getting more knock problems and/or engine running problems than you would just bad gas mileage. the plugs and wires, not likely either.2000 NBM M6 Camaro Z28<br />323/335
Plugs, wires, fuel filter, 02's, maybe cat, PCV (not a prime concern but it's like $1.50) ... do all of those and see if you still have trouble. EGR is worth mileage too, right?
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
Check your air filter and change the oil while your at it ... ;)
Maybe consider an alternative fuel. I hear the rice burners prefer a domestic like Uncle Bens.
Personally, I like alcohol. I get all the mileage I need from a bottle of Jack. [img]graemlins/fluffy.gif[/img]
[ December 03, 2002: Message edited by: apiccola ]</p>You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
<blockquote>quote:</font><hr>Originally posted by hawgs:
last tank i got 13.3 MPG... no time at the track and wasnt driving any harder then i normally drive it. the tank before i got 15.1 MPG. what are some possiblities? its got 40,000 miles have not changed fuel filter ever have run a bottle of STP fuel system cleaner through a month ago...<hr></blockquote>
Sounds like my car.
Best highway mileage in 65K miles has been 21mpg.
Usually in town...14-16mpg.
But it runs a whopping 17.8@75mph in the 1/4 mile.
Can't find anything wrong either.Max<br />\'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. 17.82 @76.101mph 2hp/5ft-lbs. :<a href=\"http://www.home.earthlink.net/~airspeedy2\" target=\"_blank\">The Home Page</a> <p>\'99.5 F-250 SuperDuty CrewCab, PowerStroke Diesel, 2wd, Torreador Red, TS Perfomance \"Insane\" Chip, BTS Tranny & Triple Disc Converter, Maddog Stage 2 Injectors, Holset H2E Turbo (36+ Psi), Detroit Locker, 33x12.5x17 Pro-Comp A/T on Eagle 118 17x8 Chrome wheels ......13.98@101mph. <p>Your resident California Licensed Smog Tech. :)
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...8 hours ago
