How To Test Coil on 3.4? - FirebirdV6.com/CamaroV6.com Message Board
  • How To Test Coil on 3.4?
    I removed my coil on my 3.4 and i have my tester out now whats the proper way to test the coil?
    From Autozone.com:
    IGNITION COILS
    1. Remove the ignition coil(s).
    2. Using an ohmmeter, check the resistance between the primary terminals on the underside of the coil. The resistance should be 0.50-0.90 ohms.
    3. Check the resistance between the secondary terminals. It should be 5000-10,000 ohms.
    4. If the coil failed either test, replace the coil.
      Viper do you or anyone else know how to test the ICM? I've posted this in the advanced tech area but got no response.
      Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
