Rear Defroster Broken - FirebirdV6.com/CamaroV6.com Message Board
  • Rear Defroster Broken
    My rear defroster suddenly doesn't work. When I push the button, I here the little click, but the light doesn't light up and my defrosters never come on.
    Has anyone else has this problem. What broke?
    2002 Navy Blue Metallic 3.8 Camaro M5 - Y87, Sport Appearance, T-Tops<br />SLP CAI, K&N, Whisper Lid, Pro 5.0<br />Dynomax Super Turbo, 2.75 I-Pipe, Fasttoys Quad Tips<br />Kenwood KDC-MP919, Kicker IX405D, Focal Polykevlar 165K2s, JL Audio 10w3-2 Stealthbox
    did you check the fuse/relay? check the ground and connectors. there are alot of things that can break but unless you have/get a multimeter, you need to just take it to the dealer.
    2000 3.8 A4 Pewter Camaro
      Mine did the same thing when it was under warranty. They replaced the whole HVAC and it worked for a while, then it went out again, now it works but the auto off feature doesn't work. I would say try to find a replacement HVAC and pop it in there to see if it fixes the problem.
      g
      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
        Dont just throw parts at it, get a Digtial multi meter. Check if power is getting to places, check grounds ect. You can get a craftsman for like 50 without autodetect for voltages ect. Just don't blow your fuses.
        1999 Pontiac Trans Am M6 Far from stock.....
          step on pull the thing gm put in there
          step2 replace with a fuse of the same AMP rating... i haven't had any problem since !!!
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            I was thinking on swapping out the 30A fuse, but I tried moving the properly working fuse from the power window circuit into it and the defroster still didn't work...this makes me think that a new fuse wouldn't help.
              its not a fues its realy thing that over heats..... i think it says 30A on it YOU MUST USE a 30A fuse a 25 amp will blow out.. as the defroster draws about 27 amps.....
