cleaning the injectors - FirebirdV6.com/CamaroV6.com Message Board
  • cleaning the injectors
    is putting injectors cleaner in your tank the only way of cleaning them?? because if i remove an injector how can i get inside of it to clean it?? duh!! or does it mean buy new ones??
    been discused many times before, use search next time
    http://www.cruzinperformance.com/fuelinj.html
    Fighting Texas Aggie class of 2008<br />black 3.4 T-top bird<br />- K&N CAI - magnaflo catback - slect coils - catco cat - tb coolant bypass
      thanx any ways for nothing
        wtf, it is what you asked for, a way to clean your injectors. and we already have our resident aholes, no room for more, so try not being a dick
          DONT COME WITH YOUR INSULTATIONS, IT ONLY REFLECTS YOUR WEAKNESS
          God bless you
            insultations?
            \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
              I put fuel system cleaner thru my car to clean everything up.
              http://www.bowtiev6.com/
                3.4ornothing ,why are you trying to make life hard 4 yourself!, get a bottle of STP injector cleaner , chuck it in with your gas, and be happy. if this does not work then replace the injectors, metaphoriclly speaking... you are trying to clip your toenails with garden shears .good luck
                  you are right,, i will do that ,,thanx
                    I got crazy with my injectors. i had them off to put a new fuel rail on, so I decided to clean them. i used aligator clips to connect the injectors to a 9V battery and I opened them. Then I shot carb cleaner into the open injector and blew compressed air through it.
                    I only pulsed them open for a few seconds at a time though. Injectors are nothing more than solenoids, they can overheat and melt the coil inside.
                    1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
