First I drive the car untill its fully warmed up. Then I let it sit for a little and it cools down. I get in and turn the key, (the temp is at 170 usually when this happens) I start the car, it idles for a split second at 500 and it then revs itself to about 2000(usually in between 1500-2000). What could cause this. The spark plugs, wires and fuel filter are brand new.
Engine revs itself after starting?
that was one of the symptons that i was just having..turned out to be my mass air flow sensor..i have a brand new one on the way..i unplugged the MAF and stripped the 102 code out with HP Tuners to run the car in speed density mode until it gets here..now it runs a TON better<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
well my car doesnt have an maf so mabye its the IAC or IAT or whatever the sensor is called that is attatched to the intake tube.1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
oh right.. 3.4s ..from what i've read it seems like those guys usually start with the IAC<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Try removing the IAC and cleaning it out, buy a gasket and remove the throttle body and give it a good cleaning. The problem is occurs from a small instant vacuum leak. Make sure that all tubes and hoses are good and installed correctly. The slightest leak will cause that rev until the PCM corrects for it.Previous F-bodies<br />1.1980Z A3<br />2.1991Z A4 5.0<br />3.1994 coupe M5<br />4.1993 TA A4<br />5.1998 coupe A4<br />Currently restoring a 1980Z<br />and looking to pick up a 1998-2002 M5
