If you look in the ashtray you will see a little hole in the corner. WHen you remove the ashtray you see a sensor or something hanging there with wires attached to it. What is it and what does it do.
Ashtray sensor?
its just a covered light. I believe the cover is on it so it doesn't heat the metal up.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...22 minutes ago
