For a 3.4
I'm having the same oil leak problem described here. I need to remove the upper intake manifold for this job, but in my Haynes manual it says to drain the coolant.
I hate coolant replacement; do I have to drain the fluid or not?
Second...is there anything else I should know before I tackle this job? I'm going to replace my upper intake gasket, the oil pump O-ring, and fuel injector O-rings...anything else I am missing?
Thanks for all of your help [img]graemlins/banana.gif[/img]
