Do I need the heat shields on? - FirebirdV6.com/CamaroV6.com Message Board
  • Do I need the heat shields on?
    I recently did my plugs, and wires, and when i did, i pulled the heat shields off the exhast manifolds...
    Now when i went to put them back on, the bolt that is built into the manifold is all stripped, and the nut will not screw back on, and i bought new nuts, and washers and that didnt work either.
    I am getting ready to leave for florida and need to get this fixed.
    I dont see why i'd need them on, other than keeping heat away from the plug wires but i made sure they arent touching / wont touch.
    Anything reason u know of why i'd need them back on?
    And if i do, what are my options of getting them on with stripped bolt thread.
    *Matt
    Re: Do I need the heat shields on?
    the only one you must put back on is the one for the starter
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      its a good idea to put them back on if you can to try and keep that heat out of the engine bay as best as possible
      http://www.bowtiev6.com/
        What do u guys think i should do, cuz those bolts are fukkked up...
        They actually seems to come off fine, but when i went to put em back on they werent goin on at all..
        any tricks u might think of ?
        Dont they make some sort of nut with nylon threads.. that might melt tho.
        *Matt
          just get some header wrap if your that worried about it
            Viper you have AIM?
            Not neccesarily worried but i will be driving from chicago to orlando in 3 days and i dont want to run into any problems..
            Header wrap sounds like a good idea though.
            My s/n is strtracer9803 on AIM, im me if u can.
            *Matt
              Viper you have AIM?
              just AIM'ed you BTW under the name and post count just click on the little IM thing to AIM anyone
                or you can use the new PM feature on our boards to talk to others privately ;)
                  only mods can PM last i knew :slap:
                    why do you have to put the starter heat shield back on?
                    I didnt, dont wanna do anything bad..
                      the starter will over heat, then won't work and you will ahve to wait for it to cool before you can start your car again
