More Blinkers Woes.... - FirebirdV6.com/CamaroV6.com Message Board
  • More Blinkers Woes....
    Well, i've changed the bulbs, checked some of the wiring. Looked at the fuses. Still no blinking action... All I want to do is just push the handle down, and let the blinker blink!!! I'm tired of doing it manually.
    So I need a check list of what to look for. Like, connections, where they are. I'm just confused now, any help is appreciated. Thanks.
    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
    Do all the lights just light up and stay lit without blinking? Is the problem only in 1 direction?
    What about the hazard lights, do they work?
    Matt
    1998 Mystic Teal Camaro M5
      The hazards work. If i push the blinker down, the light just stays on. It does this for the left or right.
        Sounds like the turn signal flasher is dead. You can get one for under $10 at a parts store.
        Matt
          Ok, cool i'll definatly try that. Where is it located in the car? and how would I go about fixing it? Thanks a lot
            They're under the dash on the driver's side. Just gotta remove that one panel. Here's a pic of it from a 98 (#4): http://www.leadingedgesim.com/mkapro...o/Flashers.jpg
            And here's a pic from a 95 Z28: http://shbox.com/1/flashers.jpg
            Matt
              Thanks for help, i'm probably gonna try this out tomorrow. I'll make an update soon.
