got it running again - FirebirdV6.com/CamaroV6.com Message Board
  • got it running again
    ok i got it running but its running bad im getting a scan tool tomm and going to run it but its really shakey and i dont think my thermostat is opening anyone know how i can force it to
    1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
    really shakey is what mine did when i had a couple plugs and wires switched. glad to hear shes breathing though.
    2000 3.8 A4 Pewter Camaro
      Same thing happened to me when I finally got the engine back together. My problem was a plug wire that was getting cooked through. Changed it out and all is well (except for that mystery water pump leak).
      98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
          Devon, what makes you think its not opening? Is it overheating?
          95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
            yeah i belive its prob a bad plug wire by my dumbass forgot to chage them i guess i didnt wna to spend like 60$ on them because i thought mine were still good but i guess 125,000 miles on stock wires arnt lol my fault and yes the thing is overeating the fans kick on and the thing still want open so im going go buy another 1 tomm and try to see if that helps but i figured its either a misfire or coil gone bad or wiresomething liek that also i sound liek my power steering pump pulley is rattling or something from that area any 1 had this prob and finally why my car was grinding is beacue i had it in between 1st and 2nd but it showed that it was in parkof the shifter so just a little fyi
              Make sure you bled all of the air out of the coolant system. It looked full to me but still had alot of air and that was causing mine to overheat at first.
                ohps i didnt bleed mine at all how much are the taylor wires if anyone knows
