ok, 98 firebird, i need to get the passenger door off so i can get at all the bolts on the crappy monsoon speaker which pretty much disinegrated. i know i know look at the guide to replace the window motor, well i did, it got me most of the way but it seems like the closer i get to the hinge something just will not give up, i got the bolt behiend the handle, under the handle, and in the door pocket, plus the little trim piece behiend the mirror, i cant see any more bolts, it just does NOT want to litf out, the part farthest away from the hinge will come, but after i progress a little further in it will simply not budge, any suggestions will be appreciated:twak:
baaaah door
Re: baaaah door
I don't understand -- you trying to remove the passenger door completely? Maybe it's safer not to do that unless you really know what u are doing. Suggestion - if you are trying to get at some metallic nuts and bolts inside the door or hard to reach places, you could try using one of those magnetic telescopic thingys which looks like an antenna. They should sell it at home depot or auto hardware store.
Re: baaaah door
noooooo, not the whole door, just the interior panel, but that sob wont lift off closer to the inside by the speakers, if you are looking at the door open, the right side of the panel i can get to come up, the left side wont budge, its acting like there is another screw but i cant find it for the life of me
Re: baaaah door
They build some of the components of these cars like a jigsaw puzzle. Even when it looks like there is no way to dismantle it, there is probably an easy way to do it. But if you don't have the dang service manual or never worked somewhere where they showed you how to do it, it could prove a hellish experience. Do you have the manual, does it say anything in there?
Re: baaaah door
manual doesnt say anything, i just need to get a service manual, wouldnt hurt in the future anyways, i just have to be missing something, it seems that that whole door pocket thing should come off, but i dont want to force and break anything :(
Re: baaaah door
Originally posted by HokieBirdJust wait until you have to get the panel back on. Thats the hard part. When you can get it on and off in under 2 minutes you will know that you have taken them off entirely too many times.
Re: baaaah door
I actually drove around a couple days without the panels :D2000 M5 Pewter Firebird [Monsoon stereo]<br /><a href=\"http://www.centerlinewheels.com/sub_wheel.php?mw_id=2\" target=\"_blank\">16\" Centerline Galaxy Wheels</a> . <a href=\"http://www.bfranker.badz28.com/headlightfix/\" target=\"_blank\">Headlight fix</a> . Under dash lighting . Dashmat . Headlight conversion<br />84k miles<br /><br /><a href=\"http://www.cardomain.com/id/tucsonbird\" target=\"_blank\">Cardomain</a><br />Tucson, AZ
