Is there any way to modify the temp gauge - FirebirdV6.com/CamaroV6.com Message Board
  • Is there any way to modify the temp gauge
    Is there a way to modify the stock temperature gauge on the 2000-2002 more accurate.
    Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
    The only thing I could think of is to check the aftermarket to see if there is a digital gauge you could use that reads directly from the PCM.
    Previous F-bodies<br />1.1980Z A3<br />2.1991Z A4 5.0<br />3.1994 coupe M5<br />4.1993 TA A4<br />5.1998 coupe A4<br />Currently restoring a 1980Z<br />and looking to pick up a 1998-2002 M5
      yeah it really does suck... autotap? Hp tuners?
        btw that and ****ty tach lag as well...
        you think as technology advanced our guages woudl be more accurate.
          Does the temp guage read directly from the sensor or does it get its info from the PCM? Maybe a better, more accurate sensor is needed.
