POS won't start again, I need help! - FirebirdV6.com/CamaroV6.com Message Board
  • POS won't start again, I need help!
    This is pissing me off soooo much, I have zero patience for this.
    What I know:
    Battery fully charged.
    Turn key in ignition and fule pump comes on and fuel lines are full.
    Purge, master, nitrous etc all work.
    Starter was replaced last weekend.
    All fuses checked and are fine.
    All relays checked and are fine.
    No SES codes
    After starter was replaced car started up beautifully several times.
    Now, it won't start.
    WTF is it?????
    I will probably post this in a couple sections because I was planning on leaving at 2:30 today to run... that f*cking ain't happening now.
    Help, please help.
    Re: POS won't start again, I need help!
    All wires checked and rechecked..
    Starter checked and rechecked..
    No cuts in wires
      Are you getting fuel? Spark?
      2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
      1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
      1974 Silver Chevrolet BIG BLOCK Corvette
        Starter doesn't crank?
        do you have a way to see if the starter is getting voltage? (test light or multimeter while someone tries to crank the motor?)
        Have another battery you can try? Can you jump it?, knowing you, you have a crazy super lightweight battery, might not hold a charge so well.
          ya you didnt say what exactly is happening...is it cranking with no fire? or no crank?...sound stupid but neutral safety switch??
          05' CTS-V
          00' Camaro - SOLD :(
            Fuel confirmed
            Spark confirmed
            Battery is fine
            I need to check to see if styarter is getting voltage.... how do I do that?
              Originally posted by 12secondv6
              Fuel confirmed
              Spark confirmed
              Battery is fine
              I need to check to see if styarter is getting voltage.... brb
              are you able check to see what position the pcm thinks the shifter is in?
              05' CTS-V
                How?
                I am retarded with electrical.
                  Fuel confirmed
                  Spark confirmed
                  Battery is fine
                  volt meter :drool: could it be the solenoid though??? there should be 2 wires...main power and a small one to tell the starter to engage if you have someone to help you put the volt meter on the little wire and try and turn it over...if you get voltage, the solenoid went bad.
                  05' CTS-V
                    It is 6 days old.... it could crap out that quickly?
                    It's just me here
                      How?
                      dont you have all those nifty computer programs??? I know with the tech2 you can see what position the trans is in and what it's commanded to be in....I though you guys could do all that stuff with the tuner software?
                      05' CTS-V
                        I don't have tuning software.
                          It's just me here
                          get a long wire attach that too the little wire then run that up into the car hooked up to your voltmeter and try cranking it.
                          and Ive had brand new starters that didnt work...
                          05' CTS-V
                            ugh, I though all you fast guys had all that software and such...ok jiggle the damn shifter then :D
                            05' CTS-V
                              BRB, ages ago I had the sfirter solenoid crap out
