Everything works fine, but my SES light came on. Are there any of you that have done your own switch according to those directions, and did your SES light come on? Any of you know off hand what I may have done wrong? Thanks.
2002 M5 Camaro 3800<br />1LE Sway Bars<br />Hurst Billet Plus Shifter<br />3.23\'s<br />Ghetto Whisper Lid Mod<br />Ghetto Ram Air Mod<br />Taylor Wires<br />Holly Powershot Filter
AFAIK, they'll come on if you start the car with the fans running inappropriately. Did you install LEDs as well? You'll see that the low speeds are on with the A/C. Many have reported that the computer learns that you're playing with the fans, and eventually stops throwing the SES. The SES light will also go away after a few starts, so nothing to worry about.
The light will not FLASH because of the fan switch, though, so keep that in mind.
-Rob
I used the directions from the site and the only time that I get a SES light is if I leave the fans on till the temp drops below normal running temp. it will go away after you shut the car off (like over night) Hope that this helps.
Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
