oooo now were in gen tech.... well neways i just leanred that our comp stores are SES codes as long ans we dont disconnect our batt in the mean time so im havin it checked out 2morrow :cross fingers:
electric prob AGAIN i guess it wasnt the alt *UPDATE*
Originally posted by pontiac nino:
I still think it might have to do something w/ the pull on the alternator maybe a smaller one don't you think?
ok so i got the code checked out...
P0151 o2 signal low Bank 2 Sensor 1
he said use 89 oct gas... i dont think the code is related to the else prob.
we hooked it up to the multimeter and it was reading 14v with the car on and i pushed the brakes constantly for a cppl min to get the voltage to drop... the voltage drop was showing thru the voltometer in the camaro but NOT on the multimeter hooked up to the batt and alt... so what does this mean??? i also had my TB cleaned while i was there cuz it was NEVER cleaned b4.
the mech said that the idle rpms is low and the alt doesnt pump out that much amps at 600~700rpms so maybe thats the pron and if it is how can u raise the idle rpms?
EDIT: i looked in the archive and code P0151 is for DTC P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
what does this mean????\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
we need some more help thats y we sent this to gen tek\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
Hmmmm... not sure about that code kamaro. First, the tech was right about alts not outputing much at idle, however, did you tell him you have a H/O alt? Regardless, those with the stock alts are not having this problem. The only thing you can do to raise idle output from the alt is to actually raise the idle RPM. No modifications should be necessary! It's all stock! There is obviously something wrong here. Changing pulley size or idle RPM or anything for that matter should NOT be the answer. I'm still stumped.
311 have you changed your battery yet?
this is so confussing, and yes they kno its a HO alt cuz they installed it 4 me. i asked them about adjusting the idle and they said that they would clean the TB to see if that would help the idle... it didnt so im goin back today(friday) and seein what they could do.\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
where can we get a smaller pully for our HA alt? i kno it shouldnt come down to that but if it fixes the problem ill b satisfied this is really gettin on my nerves... how can we adjust out idle\"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
http://www.texas-speed.com/
That's where I last saw a pulley for a alternator, hell ask Matt im sure he'll help you out---Niño---<br /><i>95\' silver 5 spd</i>
Thought I'd chip in that I've been having the same problem. Three months ago my alt died, so I went and bought the reman. advanced auto alt and installed it the same day, it fixed the problem. One month ago the (stock) battery went, so I bought a new battery, and everything was fine. Until a week ago.
I started the car one night to let it warm up, ten minutes later I come back and the charge is almost in the red. So, I kill the stereo and start heading home. The charge fluctuated the entire ride, and I made it home. It's been doing that since. I've replaced the alternator AGAIN, and I've tried various things, but myself or my master mechanic boss have not been able to figure out why the battery isn't charging, or holding a charge.
On top of all of that, just yesterday my speedo has started to act up, reading 70mph when I'm doing 55.1996 Hunter Green Chevrolet Camaro A4 Y87 - 3.8 Series II V6 (200k and still going strong)<br />Flowmaster 80 Series Muffler, SLP Cold Air Intake
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...2 hours ago
