ok i got the car for free after it sat for a while at my cuzes shop getting preped for paint but it ran i brought it to my house stated working on it and such getting it ready for summer then yesterday i went to start it and it wouldnt start it just studdered so today i changes the fuel filter drained the old gas and put in almost a half tank of fresh gas i also cleaned out the throttle body and such but it still wont start it dosnt even studder as much anymore. the check engine light also came on. idk what it could be as im only 15 but im thinking mabe fuel pump? how much would a new one be and how hard are they to change?
thanks steve
ok well now it studders and will pop occasionally but still will not start and it has enough voltage as its on a charger as im trying to start it. the check engine light is still on. i just dont know what it could be i checked the fuses all the connections ext
cleaned out the throttlebody and injecters and any other fuel line i could clean the old gas was dirty and clogged it up pretty good but its good to go now
