not starting - FirebirdV6.com/CamaroV6.com Message Board
not starting
  • not starting
    ok i got the car for free after it sat for a while at my cuzes shop getting preped for paint but it ran i brought it to my house stated working on it and such getting it ready for summer then yesterday i went to start it and it wouldnt start it just studdered so today i changes the fuel filter drained the old gas and put in almost a half tank of fresh gas i also cleaned out the throttle body and such but it still wont start it dosnt even studder as much anymore. the check engine light also came on. idk what it could be as im only 15 but im thinking mabe fuel pump? how much would a new one be and how hard are they to change?
    thanks steve
    Re: not starting
    The fuel pump is an expensive and labor intensive enough repair that you don't just "decide" to replace it on a hunch on our cars.
    You either cut a hole in the car above the tank to remove it from the tank, or you remove the fuel tank to get to the pump inside.
    I would do some more troubleshooting first [got enough voltage, spark, fuel pressure, etc?]
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      Re: not starting
      ok well now it studders and will pop occasionally but still will not start and it has enough voltage as its on a charger as im trying to start it. the check engine light is still on. i just dont know what it could be i checked the fuses all the connections ext
        Re: not starting
        nm.. i fixed it
          Re: not starting
          what did you do to fix it?
          http://www.bowtiev6.com/
            Re: not starting
            cleaned out the throttlebody and injecters and any other fuel line i could clean the old gas was dirty and clogged it up pretty good but its good to go now
              Re: not starting
              the check engine light is always on if your car doesnt start, because it would pretty much just be on the on position, no oil pressure etc...
              • 187shark
                by 187shark
