160º Thermostat Question !! Updated - FirebirdV6.com/CamaroV6.com Message Board
  • 160º Thermostat Question !! Updated
    Before I installed the thermostat in my car the temperature would go all the way up to 210º, now after the 160º thermostat and the HPP3 the temperature gauge shows around 200º. is this normal? shouldn't the temperature stay around 175º? Am I missing something here?
    Thanks for you help.
    [ April 04, 2005, 01:03 PM: Message edited by: Georghino ]
    2002 Arctic White Firebird W68<br />Installed: FTRA, Carbon Fiber Whisper Lid, K&N Filter, Transgo Shift Kit, Corvette Servo, 160º Thermostat.<br />Appearance: Potenzas RE750 245\'s, 3M Tint 20% All Around, Clear Corners.<br />FOR SALE: HPP3
    depends on how the driving condtions are. slow traffic it will go up more but shold be lower if driving high way style drving. hope that helps
      I do a lot of driving on the freeway and still the temperature goes up all the way to 200º. Any other suggestion to what may be causing this?
      Thanks
        Have you ever cleaned out the fins on your radiator? Dirt, leaves, trash, etc get in there too and clog up the airflow. Either a air hose or hard stream of water should do it. Spray directly into the radiator from both angles (front & back). Make sure the radiator isn't hot if you're spraying with water.
        Also, check your airdam under the car. It brings in air to cool the rad. Check to see if it's broke, cracked, etc.
          so, is the temperature suppossed to be at 175º now that I have the 160º thermostat and the HPP3?
          Thanks
          [ April 02, 2005, 02:23 PM: Message edited by: Georghino ]
            Mine wont touch the halfway mark (I'm at work, so I can't see what temp that is) It normaly sits right blow the first notch, and in heavy traffic slightly above it.
            94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
              On mine, at idle temperature rises up to 220, driving over 40 mi drops to the 170
                so, it should be at around 175º. That means that there is something wrong with my car because the temperature in my car never goes below 200º even when I'm driving in the freeway (usually at 90 mph).
                I know before the thermostat my car used to run at 210º so I've already gotten a 10º drop from the installation of the thermostat but I was expecting something more like a 35º-40º drop in the temperature.
                Any other info?
                Thanks
                [ April 02, 2005, 03:16 PM: Message edited by: Georghino ]
                  When installing a thermostat, people often don't realize that you also need to change your fan timing for your radiator. If you put a 160* thermostat, it is only going to keep the fluid running all the time because the temperature won't drop. You should also change your radiator fans to turn on at around the same temperature as the thermostat (or something like that). This is the reason i don't mess around with my thermostat, because i dont have the programming to change my fan timing, that way it is kind of only being half used.
                  Someone with more knowledge should chime in here.. i know people understand what i am trying to say. sorry for being a little confusing.
                  -Scott
                  <a href=\"http://home.comcast.net/~beer13oy/carpage.html\" target=\"_blank\"><b>1995 3.4 Liter M5 Camaro</b></a><br />A few mods...<br />still slow.<br /><br /><a href=\"http://www.mnfbody.com\" target=\"_blank\">Minnesota F-body</a>
                    i dont kow if this would do anything but when u instaled the thermo did you bleed the cooling system to get the air out
                      NO, I didn't bleed the cooling system. Do you think that would be a problem? I don't even know how to do that.
                      Also, 95DGcamaro. I have the HPP3 so I reprogrammed the computer also with the 160º thermostat option.
                        it could be causeing a problem there could be to much air in the coolent
                          also check your coolant level lol
                          i know it sounds simple, but if u are low, it will cause your engine to run hotter than normal
                          1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
                            there is a little bleeder at the top of the thermostat housing to bleed out any air. check that.
                            http://www.bowtiev6.com/
                              on your hpp3 when u did the 160 mod on it does your fans come on when it hits that cuse i have the same set up hpp3 and 160 t stat but my fan come on like if i never programed it in other words stock setings why is that?
                              2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
