Stock battery hold dwn. Will it pass tech? - FirebirdV6.com/CamaroV6.com Message Board
  • Stock battery hold dwn. Will it pass tech?
    New england drageway requires a battery hold down. Will the stock battery hold down pass tech inspection? I dont want to go all the way to the dragstrip for nothing.
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
    yes
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      assuming your stock hold down still works...
      which if yours is original you are probably one of the 10 from 1995 that are not broken.
      do a search on it, I made a post and a few others did on how to make a cheap one, for when one breaks.
        Eric, where is this post?
        ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
          Took me 5 seconds to find. ;) [img]tongue.gif[/img]
          http://www.camarov6.com/ubb/ultimate...1;t=015235;p=1
          Matt
          1998 Mystic Teal Camaro M5
            Lol, thanks bro. I didn't really know exactly which words to search, I guess just battery hold down....but I figured somebody would remember the post and find it easier. Anywho....
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
