A/C - FirebirdV6.com/CamaroV6.com Message Board
A/C
  • A/C
    Well yesterday was nice, till it got to 80degrees, why can't it just stay at 72-75 all day.
    Anyways, it was getting hot, so I pull into a garage and they check my a/c, and then recharge it. They put a thermostat in the a/c vent 47 degrees [img]graemlins/banana.gif[/img]
    So after I left I remembered I replaced the condenser thing last summer about 1/2 way through the summer and had it recharged. So now I'm thinking I may have a small leak somewhere. Bummer.
    I seem to have a small refridgerant leak myself also. I recharged it properly with tools and gauges so cool air flowed through the vents but it gradually faded away after 3 days. Now I have room temperature air from the vents. I also need feedback as to why and how I can rectify this small problem, Im staying tuned.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
      just take it out
      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
        Originally posted by Little G:
        just take it out
        X2 ... and you cant say that i live in a cold region... STL gets in the 100* range every year with 90% humidity
          Unless you have a leak detector or put some dye in the system and have the system recharged you will never find the leak. A word of advice though...don't be stupid and go to Walmart and buy that stuff that seals as leaks..that is unless you really want to replace your whole ac system at a cost of...shall we say ALOT
          2005 Magnum
            When my older systems leaked, I used refrigerant from Interdynamics (from Wal Mart) that had the R134A, seal conditioner, and oil all in one can. It worked well for several years until I dumped the car. I think that as long as your leak is a weak seal, that stuff is OK. But if you have a leak anywhere but a seal, you have no choice but to get the part replaced.
            L1tech, is this the stuff you were referring to, or is there an actual "stop leak" product, kind of like for radiators? Something like that I would NEVER use.
              You can buy a dye kit for 20 dollars, but they are a pain still to find the leak, You could always take it to a dealer, they you help you out with you wallet.. hehe
              255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
                The problem with buying the can of stuff that has everything in it...oil and whatnot..is that you have no way of knowing how much oil is in your system already, so now you use this stuff and have way too much oil in there and now your ac doesn't work properly because there is to much oil in the system...what do you do...put another can in..now there is 2x too much of everything in the system..if you didn't have a leak before you will soon. Ac is a simple concept, however without the proper tools and UNDERSTANDING of how the system works you are just going to loose your cool..yeah that was corny...adn cost you more money in the long run than if you had a pro do it in the first palce
                2005 Magnum
