Oil Leaks - FirebirdV6.com/CamaroV6.com Message Board
Oil Leaks
  • Oil Leaks
    if u have a rear main seal leaj where would it leak from>? i checked where the oil is leakeing from and its up on the passenger side by the manifold. but not from the oil pan. it also leaks and drops orund the front of the engine around the p/s tube. I cant tell if its leaking from Atop of the trans. what is the rear main seal all about?
    i appreaciate any input concerning this blast oil leak.
    Re: Oil Leaks
    it sounds like your valve cover gaskets are leaking.
    a rear main seal leak would be in the rear of your engine, down by the tranny
