2000 PCM in a 98, is it a simple plug and play swap? - FirebirdV6.com/CamaroV6.com Message Board
  • 2000 PCM in a 98, is it a simple plug and play swap?
    going from a 98 a4 w68 PCM to a 2000 a4 y87 (I have the gears installed) is it a simple plug and play swap or is it more in depth?
    1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well see
    98 PCM is drive by wire
    00 PCM is electronic controlled TB
    meaning.. nope, not at all.
      <blockquote>quote:</font><hr> 98 PCM is drive by wire
      00 PCM is electronic controlled TB <hr></blockquote>
      [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
      The 98 is mechanically operated. The 00 is electrically operated(drive by wire). I believe that the computer would trigger a fault code because it wouln't see a signal from the accelerator pedal but it would see a change in signal from the TPS. Can't say that for sure but I am almost positive.
      \" As being is to becoming, so is pure itellect to opinion, so is science to belief, and understanding to the peception of shadows.\" - Plato
        I had decided not to say anything about that last night... because I guess you could say the 98 is drive by wire if you call the throttle cable a wire [img]smile.gif[/img]
        Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
