V6 heads - FirebirdV6.com/CamaroV6.com Message Board
V6 heads
  • V6 heads
    HI. i have 1996 pontiac firebird V6 (of course) but i have not been able to find heads fot it anywhere. i have had people tell me that stuff for the newer models will work to but i have not been able to find any heads for those either. does anyone know where i might be able to find some or do they even make them for the V6?
    Re: V6 heads
    http://www.abbottracingheads.com/
    2000 3.8 A4 Pewter Camaro
      Re: V6 heads
      also.. www.supersixmotorsports.com
      Follow me!
      Or this
        Re: V6 heads
        Thanks for the help guys. i just have 1 more question.....i live in the columbus ohio area and i was also looking into maybe just gettin my heads done instead of bying new ones.....anyone have any idea if there is anyone in this area or just anywhere in that i can take or send my heads to get this done? Or just any way i might be able to find a place?
          Re: V6 heads
          well since youre in ohio check out www.columbusracing.com we have a few members on here that are over there also. the columbus guys should be able to help you out a bit in your search.
          also... check out the Redlinev6 forum towards the bottom of the main forum here, there are going to be quite a few meets going on this year for us ohio peeps.
          Follow me!
          Or this
            Re: V6 heads
            cool....thanks alot for the help
              Re: V6 heads
              no problem :)
              Follow me!
              Or this
              • Andy H
                Transmission removal help!!
                by Andy H
              • 2.8 Bird
                Abs inop
                by 2.8 Bird
              • fishin
                by fishin
