every now and then when i start up my car it fires up like the ignition turned over but really the car hasnt started and just the radio comes on. then i give it a second and and turn the key again and it fires up fine. i really have no idea why its doing this. it seems to happen every once in a while but becomes annoying. i havent gotten my spark plugs and wires changed yet and im planning to do that soon. could it be that or a starter or bad ignition? anyone that has had this problem i am all ears.
problems starting up the car
Re: problems starting up the car
Tune up might help.
Maybe battery is a little on the low side.
Maybe fuel pump's getting lazy.
Maybe clogged fuel filter.
I'd start with #1 and 4 on the list.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
i was reading soemthing on the net and some guy said he had problem iwth his v6 camaro similar to mines his was a bad ignition ground wire. i dunno f thats it ill figure it out in a week or so.JpX
could be a number of things. could be your starter, could be your fuel pressure regulator, could be the purge solenoid, its a shot in the dark from my perspective. Ive had the same problem forever, like it turns over but doesnt start for a while and if i try again it starts right up.SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...3 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...4 weeks ago
