tire qestion - FirebirdV6.com/CamaroV6.com Message Board
tire qestion
  • tire qestion
    Ok so I have a flat tire, I drive it to fix et when I look at the tire the front pasanger tire, has no tread on the inside(closer to the engine) WTF this is the only one that has it why it happen and what can I do?? (today I’m moving the tire to te beck but I don’t want te next tire look like that. Help)
    Re: tire qestion
    You probably need a wheel alignment. It sounds like you have bad camber on that wheel.
    Representin' Team Red In The North
    Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
    Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
    Black/Red '02 Honda CBR 954RR Fireblade
      Re: tire qestion
      Maintain the proper tire pressure.
      rotate them reguarly.
      get a front end alignment.
      check for worn suspension/steering components.
      \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
        Re: tire qestion
        The current pressures should be posted inside your driver's side door (on the jamb). If you are not using factory size tires, go max pressure for the tire minus 5 or so.
        Every 10K (after an alignment)
        get a front end alignment. check for worn suspension/steering components.
        :tup:
        http://www.cardomain.com/memberpage/799659
          Re: tire qestion
          What exactly is a alignment ?? the car those not pull to any sides the car is going strait do I still need it ?
          I can only rotate the tiers from front to beck because of the tire (>>>>)
          Also then I took that tire off is all cut put I has a little paces of metal like a poop can metal I took all of them out but I thing I’m gone need a new tire,
            Re: tire qestion
            Here is a brief article on what an alignment is.
            http://autorepair.about.com/cs/gener.../aa012201a.htm
            As an extreme example of camber, think of a NASCAR Nextel Cup car. When traveling down the straights, the tires are leaning to the left riding on the edge of the tire. At this point they are ony using a small portion of the available tire surface. When they corner, with the banking and speed, the shocks compress and the tire flattens out giving them maximum contact with the track surface.
            On a street car, it is normal to have some degree of camber set. Actually, the tires lean in towards each other ever so slightly. Any more and the tire wears uneven just like your describing. The camber setting is specific to each model car and the application your using it for (autocross). While some people may disagree, I believe in getting an alignment every 15K. Its cheaper to get an alignment versus buying new tires due to improper wear.
            Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
