Need A/C Help - FirebirdV6.com/CamaroV6.com Message Board
Need A/C Help
  • Need A/C Help
    I reinstalled all my AC today all but the sensor near blower box by the PCM cause my dad broke it and Dealer didnt have one. I need that part number also if anyone has it. So i start car no prob but when i turn AC on the clutch doesnt turn on it blows air but not cool cause condenser blower isnt grabbing. Is this cause the sensor isnt on or do i have another problem.
    Thanks for any help!!
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    Re: Need A/C Help
    are you talking about the pressure switch?
      Re: Need A/C Help
      Yes thats the one
        Re: Need A/C Help
        well first off, did you charge the system propery? I mean, did you vacuum out the freon lines before installing freon? My next question is what part did your dad break, the upper part with the wires, or the metal part that is on the freon line its self...if thats the part thats broken it would be my guess that it is now leaking freon. If you can not find a replacement part, and worst comes to worst, you can just bypass the switch. im not sure which wires to put together, but try touching them together one by one, then all 3 together, worst thing that can happen is blow a fuse.
          Re: Need A/C Help
          or if you can wait abit, i will go out to my switch and tell you what wires to put together
