heres my question after like 8months of havin it i hooked it up the car fires up but it sounds like it may be missin or somethin cuz the car has a consistent bluh bluh bluh like its cam'd and i dont know if its the plugs, timing or what else it could be any ideas? The car has been parked for the winter i did start it up and all that good stuff, but it does blow a lil carb out and what seems to be a lil water(which i kno gms do) but i dont think its all carbed up cuz i blew it all out
I'm guessing your name is about your car so make sure you have the right wiring for the 3.4L. If you got the diagram off this site, it's wrong... I went through that already.
Just call MSD and spend 5 minutes on the phone with them, they'll give you the correct wiring and it should work perfect. Thats what happened to me at least..
i didnt use the guide off this site i did it by the manual the car starts so im assuming it has to be right cuz if it wasnt they said it wouldnt start but im not postive how accurate that statement is by MSD
alright now the car dont even just sputter any more it stalls out..oh ya and it does all this with the bypass plug in so its not the box doin it what exactly was your diagram Batmobile i used Coil
Heavy Red(power lead)-to power junction
Heavy Black(powerlead)-grounded
Red1-hooked up to channel 1 and 2 12volt source wire
Red2-hooked up to channel 3 12volt source
White- hooked up to trigger source of channel 1
Green- hooked up to trigger source of channel 2
Yellow-hooked up to trigger source of channel 3
Violet-grounded
