Help need quick reply - FirebirdV6.com/CamaroV6.com Message Board
  • Help need quick reply
    I'm going to the drags for the first time at Infineon Raceway. They have a ton of rules and I'm just wondering how strict they are. They require a battery tie-down and I'm not even sure I have one. did our cars come with them? Do you think they won't let me run without one? After all, I probably won't even be breaking 15 seconds. The other thing is they say in he rules that the car must have only factory tinting. I have the back window limo tinted and the sides are only 50%..not that dark.
    Yes, our cars have a battery tie-down...BUT, most of them break. There is a bolt and a plastic thingy on the rear of the batttery at the bottom (underneath the cables). If they require a tie-down, then they most likely will turn you away when they inspect it. Rules are rules, no matter how fast your car goes.
    I have no idea about the tint. Just have them check it to see if it complies.
      Thanks for the reply. Ended up they didn't check anything thankfully.
